15 years agouClinux 20100621 - conneting NIOS HW with linux
Hi I can not connect NIOS hardware with uClinux kernel. I successfully did it when uClinux support make vendor_hwselect. But when I have to build my custom header file with command sopc-creat...
15 years agoDo you want networking/ethernet in your system? If so, then you'll have to resolve this. If not, then I think you can safely remove and/or switch these flags off. Just make sure you've also disabled the TSE (and related) in make menuconfig.
Cheers, slacker
