15 years agouClinux 20100621 - conneting NIOS HW with linux
Hi I can not connect NIOS hardware with uClinux kernel. I successfully did it when uClinux support make vendor_hwselect. But when I have to build my custom header file with command sopc-creat...
15 years agohave you tried giving a make menuconfig and go down to the devices deselecting the Altera Triple Speed Ethernet and leds?
I had some problems with the GPIO, I found the selection for it in the menuconfig under Customize Kernel settings > Linux/NiosII Configuration > Additional NiosII Device Drivers. Not sure this helps you.
