15 years agouClinux 20100621 - conneting NIOS HW with linux
Hi I can not connect NIOS hardware with uClinux kernel. I successfully did it when uClinux support make vendor_hwselect. But when I have to build my custom header file with command sopc-creat...
15 years ago --- Quote Start --- But when I have to build my custom header file with command sopc-create-header-files --single my_nios2_fpga.h I dont't know where exactly put it and how to configure make menuconfig. --- Quote End --- I you are using the mmu version, take a look on the steps http://www.alterawiki.com/wiki/creating_a_nios_ii_design_with_an_mmu about adding the files, copying the folders in arch/nios2/ and so on
