20 years agoUart RF Link?
Hi Guys,
I have an interesting problem that I have come across :S I think its either a problem with my code or a problem with the implementation of the Uart in Nios II. I'm trying to implement a data link from a UAV (remote controlled plane basically) and a ground computer. We are using an RF modem to transmit the Uart link from the plane to the ground. The hardware used is the hac-um96 ultra low powerdata radio module (http://www.sparkfun.com/datasheets/rf/hac-um96_manual.pdf) set to transmit and recieve on the same channel with RS-232 and no parity (8N1). Hooked up two computers using this device via hyperterminal and works a charm, press any key on one computer at any time and it gets transmitted straight away to the other. The problem comes when i use the Nios II Core with the Uart via a max-232 chip on a cyclone FPGA. While delay in the following code is less then 10000 all printf get through to the other end of the RF link (PC Nios terminal or hyperterminal). At a delay of 20000; 1 in 5 get through, 30000; 1 in 3, 40000; 1 in 7, 50000; 1 in 2, 100000; 1 in 9. All of these various delays work fine with a straight rs-232 cable link to the computer its only the RF link that misbehaves. Is there any reason you can think of that this would be happening?? Thanks Chrisint main()
unsigned int i;
unsigned int j;
unsigned int count;
/* make sure no IRQ enabled */
IOWR(UART_0_BASE, 3, 0x00);
/* flush any characters sitting in the Rx holding register */
i = IORD(UART_0_BASE, 0);
count=0;
for (;;) {
printf("Hello World! %i\n",count);
count++;
j=0;
while (j<delay)
j++;
return 0;
}2 Replies
I guess that means no one has any idea http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
Well i might try putting a scope on the Uart lines and see if there is any differance between the computer uart and the nios for say sending the letter "A" not sure what else to try... Chris - Altera_Forum
hi,
i have the same problem, did you succeed solving it? if yes, can you please tell how? hodel.
