15 years agoUart Problem
Hi everybody, I need to write or read a package to UART. Package like 0xFF 0xFF 0x01 0x04 0x02 0x2B 0x01 0xCC This package or packages like that are needed to be sent to control Dynam...
15 years agoI think you are using the standard UART controller component available in sopc builder.
You'll find all the information you need in the embedded peripherals guide, under UART section: http://www.altera.com/literature/ug/ug_embedded_ip.pdf Basically, if you need to transmit a simple characters sequence, as you ask, you simply need to init the controller (set baudrate and line control register) and write the bytes into tx register.
