21 years ago
UART Problem missing characters at 115200
Quartus 4.2 and NIOS 1.1
I want to make ymodem download, so I want use 115200 baud,
blocksize is 1026 byte.
I copied altera_avalon_uart.h and altera_avalon_uart.c in the syslib
directory and changed the uart buffersize:
# define ALT_AVALON_UART_BUF_LEN (2048)
I use Cyclone Dev. Board and standard design, so hardware should be ok.
I made a small testprogram and a loop at Tx-Rx.
I set stdout,stderr to lcd,stdin=null.
I get different results if I make my testoutputs to jtag uart or lcd.
case 1:
- tx testoutput to jtag
- rx testoutput to lcd
result: always read back 1023 characters, instead of 1024
errorcount=no of packets
sometimes after some time I get
"nios2-terminal: exiting due to I/O error communicating with target"
after this error uart1 receives correct packets with 1024 byte
case 2:
- rx testoutput to jtag
result: about 25% of the packets wrong, (only 1023 byte)
case 3:
- tx testoutput to lcd
result: about 100% of the packets are ok (1024 byte)
the critical is the tx testoutput, because in this time the
uart1 transmit and receive interrupts are running.
on my custom board I also loose characters, even I don't us
the jtag uart.
please, can someone verify the program and test results,
what's wrong ???
thanks
...# include <stdio.h># include <stdlib.h># include <time.h># include <alt_types.h># include <unistd.h># include <fcntl.h># include <sys/alt_alarm.h>
# define BYTE alt_u8# define WORD alt_u16# define DWORD alt_u32
# define UART0_RXBUFFERSIZE 2048
int uart0_rxcount;
char uart0_rxbuffer[UART0_RXBUFFERSIZE];
char uart0_txbuffer[UART0_RXBUFFERSIZE];
FILE *jtfp;
int fd0_nonblocked; // FILEDESCRIPTOR RETURNED BY OPEN
FILE * fp0_nonblocked; // FILE pointer returned by fdopen
int fd0_blocked; // FILEDESCRIPTOR RETURNED BY OPEN
FILE * fp0_blocked; // FILE pointer returned by fdopen
int com_fill_testbuffer(char *buffer,int count);
char hextoa(BYTE val);
void lcd_gotoxy(int x,int y);
int main() {
int packetcount=0;
int txcount;
int res;
int packeterror=0;
jtfp = fopen ("/dev/jtag_uart","w");
if(jtfp) {
fprintf(jtfp,"JTAG UART OPEN FOR DEBUG\n");
// BAUDRATE IS 115200,8,N,1
fd0_nonblocked = open("/dev/uart1",O_RDWR | O_NONBLOCK | O_NOCTTY);
fp0_nonblocked=fdopen(fd0_nonblocked,"rw+");
fd0_blocked = open("/dev/uart1",O_RDWR | O_NOCTTY);
fp0_blocked=fdopen(fd0_blocked,"rw+");
// txcount = 512;
txcount = 1024;
// dummy read
uart0_rxcount=read(fd0_nonblocked,uart0_rxbuffer,UART0_RXBUFFERSIZE);
while(1) {
com_fill_testbuffer(uart0_txbuffer,txcount);
res=write(fd0_nonblocked,uart0_txbuffer,txcount);
// TX TESTOUTPUT TO JTAG-UART
// fprintf(jtfp,"%04d UART1:TX:%d: \r\n",packetcount,res);
// TX TESTOUTPUT TO LCD
lcd_gotoxy(1,1);
printf("TX:%04d",res);
usleep(500000); // wait to complete trannsmit and receive
if(uart0_rxcount!=txcount) packeterror++;
// RX TESTOUTPUT TO JTAG UART
// fprintf(jtfp,"UART1:RX:%d: PACKETS:%d ERRORS:%d\r\n",uart0_rxcount,packetcount++,packeterror);
// RX TESTOUTPUT TO LCD
lcd_gotoxy(1,9);
printf("RX:%04d",uart0_rxcount);
lcd_gotoxy(2,1);
printf("PA:%04d ERR:%04d",packetcount++,packeterror);
return 0;
int com_fill_testbuffer(char *buffer,int count) {
int i,k;
unsigned int seed;
seed=clock();
srand(seed);
for(i=0;i<(count/2);i++) {
k=rand()&0xff;
k=i;
buffer[i<<1]=hextoa((i>>4)&0x0f);
buffer[(i<<1)+1]=hextoa(i&0x0f);
return 0;
char hextoa(BYTE val) {
char hexchar=0;
if(val<=9) hexchar=&#39;0&#39;+val;
if(val>=0x0a && val<=0x0f) hexchar=&#39;A&#39;+val-0x0a;
return(hexchar);
void lcd_gotoxy(int x,int y) {
printf("\x1b[%d;%dH",x,y);
1 Reply
    the uart have a buffer of 64 bytes defualt size.
    when HW syncronization is not used, if you write more then 64 chars to the buffer before the receving side reed them , chars will be lost
