19 years agoUART interrupt
I'm in the process of converting an old NIOS II project over to eCos. The interrupts do not work when I use the eCos API. Here is the relevant code.
#include <cyg/hal/system.h># include <cyg/kernel/kapi.h>
unsigned char abycin;
volatile unsigned int byrxptr = 0;
unsigned int bywrptr = 0;
cyg_uint32 uart_debug_isr(cyg_vector_t vector, cyg_addrword_t data)
volatile int clr_int;
// Block this interrupt from occurring until this ISR completes.
cyg_interrupt_mask(vector);
// Tell the processor that we have received the interrupt.
cyg_interrupt_acknowledge(vector);
if (!(IORD_ALTERA_AVALON_UART_STATUS(UART_DEBUG_BASE) & 0x02))
abycin = IORD_ALTERA_AVALON_UART_RXDATA(UART_DEBUG_BASE);
if(byrxptr < (RXBUF_SIZE_DEBUG - 2)) byrxptr++;
else byrxptr = 0;
else clr_int = IORD_ALTERA_AVALON_UART_RXDATA(UART_DEBUG_BASE); // read UDR if framing error just to clear interrupt
// Allow this interrupt to occur again.
//cyg_interrupt_unmask (vector);
// Tell the kernel that chained interrupt processing is done.
//return CYG_ISR_HANDLED;
return CYG_ISR_HANDLED | CYG_ISR_CALL_DSR;
void uart_debug_dsr(cyg_vector_t vector, cyg_ucount32 count, cyg_addrword_t data)
//printf("DSR\n");
//out_str("DSR\n");
cyg_interrupt_unmask(vector);
void out_str(char *s)
unsigned char *c;
for(c = s;; c++)
if(*c == 0)
break;
out_char((unsigned char)*c);
void out_char(unsigned char c)
while(!(IORD_ALTERA_AVALON_UART_STATUS(UART_DEBUG_BASE) & 0x40));
IOWR_ALTERA_AVALON_UART_TXDATA(UART_DEBUG_BASE, c);
void cyg_user_start(void)
int divisor = 0;
int old = 0;
cyg_handle_t uart_debug_handle, timer_handle;
cyg_interrupt uart_debug_intr, timer_intr;
cyg_interrupt_create(UART_DEBUG_IRQ, 99, 0, &uart_debug_isr, &uart_debug_dsr, &uart_debug_handle, &uart_debug_intr);
cyg_interrupt_attach(uart_debug_handle);
cyg_interrupt_disable();
/* Other initialization tasks performed here */
cyg_interrupt_enable();
cyg_interrupt_unmask(UART_DEBUG_IRQ);
while(1)
while (bywrptr != byrxptr) // Check to see if any data has been received by the Uart
printf("bywrptr != byrxptr\n");
ProcessRxBuf(); // Process new data received from Uart
//while (rtdwrptr != rtdrxptr)
//MDP();
} Is there something special that needs to be done in the nios2configtool to get interrupts to work?3 Replies
--- Quote Start --- originally posted by lee@Jan 2 2007, 11:54 AM i'm in the process of converting an old nios ii project over to ecos. the interrupts do not work when i use the ecos api. here is the relevant code.#include <cyg/hal/system.h># include <cyg/kernel/kapi.h> unsigned char abycin; volatile unsigned int byrxptr = 0; unsigned int bywrptr = 0; cyg_uint32 uart_debug_isr(cyg_vector_t vector, cyg_addrword_t data) { volatile int clr_int; // block this interrupt from occurring until this isr completes. cyg_interrupt_mask(vector); // tell the processor that we have received the interrupt. cyg_interrupt_acknowledge(vector); if (!(iord_altera_avalon_uart_status(uart_debug_base) & 0x02)) { abycin = iord_altera_avalon_uart_rxdata(uart_debug_base); if(byrxptr < (rxbuf_size_debug - 2)) byrxptr++; else byrxptr = 0; } else clr_int = iord_altera_avalon_uart_rxdata(uart_debug_base); // read udr if framing error just to clear interrupt // allow this interrupt to occur again. //cyg_interrupt_unmask (vector); // tell the kernel that chained interrupt processing is done. //return cyg_isr_handled; return cyg_isr_handled | cyg_isr_call_dsr; } void uart_debug_dsr(cyg_vector_t vector, cyg_ucount32 count, cyg_addrword_t data) { //printf("dsr\n"); //out_str("dsr\n"); cyg_interrupt_unmask(vector); } void out_str(char *s) { unsigned char *c; for(c = s;; c++) { if(*c == 0) break; out_char((unsigned char)*c); } } void out_char(unsigned char c) { while(!(iord_altera_avalon_uart_status(uart_debug_base) & 0x40)); iowr_altera_avalon_uart_txdata(uart_debug_base, c); } void cyg_user_start(void) { int divisor = 0; int old = 0; cyg_handle_t uart_debug_handle, timer_handle; cyg_interrupt uart_debug_intr, timer_intr; cyg_interrupt_create(uart_debug_irq, 99, 0, &uart_debug_isr, &uart_debug_dsr, &uart_debug_handle, &uart_debug_intr); cyg_interrupt_attach(uart_debug_handle); cyg_interrupt_disable(); /* other initialization tasks performed here */ cyg_interrupt_enable(); cyg_interrupt_unmask(uart_debug_irq); while(1) { while (bywrptr != byrxptr) // check to see if any data has been received by the uart { printf("bywrptr != byrxptr\n"); processrxbuf(); // process new data received from uart } //while (rtdwrptr != rtdrxptr) //mdp(); } }is there something special that needs to be done in the nios2configtool to get interrupts to work?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20322)</div> --- Quote End --- You're probably suffering from the fact that the eCos port already contains a driver for the UART and two drivers talking to one piece of hardware is never good
Hey thanks, I've got it working now using the cyg_io functions.
Has anyone gotten multiple UARTs to work in a single system?
My default debug/diagnostics UART works fine when mapped to "/dev/haldiag", but I have two other UARTs in the system which aren't working using the cyg_io functions. In the nios2configtool I have TTY mode channel# 0 mapped to "/dev/uart_rtd" and TTY mode channel# 1 mapped to "/dev/uart_radio". When I do the lookup for "/dev/tty0" I receive no error, but then the processor resets somewhere inside the cyg_io_read() function. Am I missing something?void cyg_user_start(void) { cyg_io_handle_t uart_rtd_handle; Cyg_ErrNo error; char readbuf; cyg_uint32 readbuf_size = 1; cyg_io_init(); error = cyg_io_lookup("/dev/tty0", &uart_rtd_handle); out_str("Error 1 = "); out_hex(error); while(!error) { error = cyg_io_read(uart_rtd_handle, (void *)&readbuf, &readbuf_size); out_hex(readbuf); out_char(' '); } }
