UART Interrupt and timer interrupt at the same time
I am using max10, DE10-Lite board.
I try to use uart interrupt for get command code.
an i also want use timer for periodic work until input command code.
but uart interrupt is work only. timer interrupt does not work.
it is my code. i want know what is wrong.
#include <stdio.h>
#include "system.h"
#include "Nios_Variables.h"
#include "string.h"
#include <stdlib.h>
#include <stdint.h>
volatile uint16_t flag = 0u;
int gpio;
void handle_timer_interrupt(void*p, alt_u32 param);
void uart_init();
void handle_uart_interrupt(void *context,alt_u32 interrupt);
extern int alt_irq_register (alt_u32 id, void* context,void (*alt_isr_func)(void* isr_context, alt_u32 id) );
int main()
// register the timer irq to be serviced by handle_timer_interrupt() function
alt_irq_register(TIMER_0_IRQ, 0, handle_timer_interrupt);
// activate the time
IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_0_BASE,
ALTERA_AVALON_TIMER_CONTROL_CONT_MSK
| ALTERA_AVALON_TIMER_CONTROL_START_MSK
| ALTERA_AVALON_TIMER_CONTROL_ITO_MSK);
uart_init();
for(;;)
if(gpio == 1)
printf("SW Lock\n\r");
else
if(flag > 0)
printf("A\n");
flag = 0;
return 0;
// clear irq status in order to prevent retriggering
IOWR_ALTERA_AVALON_TIMER_STATUS(TIMER_0_BASE, 0);
gpio = IORD_ALTERA_AVALON_PIO_DATA(PIO_0_BASE);
// your isr code here
flag++;
unsigned short int data,status;
status = IORD_ALTERA_AVALON_UART_STATUS(E_UART_BASE);
while (!(status & ALTERA_AVALON_UART_STATUS_RRDY_MSK))
data =IORD_ALTERA_AVALON_UART_RXDATA(E_UART_BASE);
//write status reg;
status = ALTERA_AVALON_UART_STATUS_TRDY_MSK;
IOWR_ALTERA_AVALON_UART_STATUS(E_UART_BASE, status);
IOWR_ALTERA_AVALON_UART_TXDATA(E_UART_BASE, data);
IOWR_ALTERA_AVALON_UART_STATUS(E_UART_BASE, 0);
void uart_init()
alt_u32 control;
control = ALTERA_AVALON_UART_CONTROL_TRDY_MSK | ALTERA_AVALON_UART_CONTROL_RRDY_MSK | ALTERA_AVALON_UART_CONTROL_E_MSK;
IOWR_ALTERA_AVALON_UART_CONTROL(E_UART_BASE, control);
alt_irq_register(E_UART_IRQ, 0, handle_uart_interrupt);
Hi Junbum, sorry for the late response. I was looking for the right answer.
Here you have an example code with the UART and Timer interruptions, the only difference is that it uses a timer init, could you compare your code with this.
* "Hello World" example.
* This example prints 'Hello from Nios II' to the STDOUT stream. It runs on
* the Nios II 'standard', 'full_featured', 'fast', and 'low_cost' example
* designs. It runs with or without the MicroC/OS-II RTOS and requires a STDOUT
* device in your system's hardware.
* The memory footprint of this hosted application is ~69 kbytes by default
* using the standard reference design.
* For a reduced footprint version of this template, and an explanation of how
* to reduce the memory footprint for a given application, see the
* "small_hello_world" template.
*/# include <stdio.h># include <unistd.h># include <fcntl.h># include "sys/alt_stdio.h"# include "system.h"# include "alt_types.h"# include "altera_avalon_uart_regs.h"# include "altera_avalon_timer_regs.h"# include "sys/alt_irq.h"
# define Switches (volatile char *) 0x00041040# define LEDs (char *) 0x00041050# define UART0_BASE (char *) 0x00041000# define UART0_IRQ 1# define TIMER0_IRQ 2# define TIMER0_BASE (char *) 0x00041020
void uart0_put_char(unsigned char ch)
while((IORD_ALTERA_AVALON_UART_STATUS(UART0_BASE) & 0x040) != 0x040){ ;}
IOWR_ALTERA_AVALON_UART_TXDATA(UART0_BASE,ch);
void uart0_put_str(unsigned char * str){
while(*str){
uart0_put_char(*str);
str++;
void uart_handle(void *context,alt_u32 interrupt)
status = IORD_ALTERA_AVALON_UART_STATUS(UART0_BASE);
data =IORD_ALTERA_AVALON_UART_RXDATA(UART0_BASE);
*LEDs=(char)data;
void uart_init()
alt_u32 control;
volatile unsigned long uart_capture;
IOWR_ALTERA_AVALON_UART_CONTROL(UART0_BASE, control);
if (alt_irq_register(UART0_IRQ, (void*)uart_capture, uart_handle)){
alt_putstr("UART0_IRQ Register Successful\n");
}else{
alt_putstr("UART0_IRQ Register UnSuccessful\n");
void handle_timer_interrupt (void* context, alt_u32 id){
static alt_u32 value = 0x00;
value = value + 1;
if(value % 1000 == 0){
*LEDs=(char)value;
IOWR_ALTERA_AVALON_TIMER_STATUS(TIMER0_BASE,0); // Clear the interrupt flag
void timer_init(){
IOWR_ALTERA_AVALON_TIMER_CONTROL (TIMER0_BASE,ALTERA_AVALON_TIMER_CONTROL_ITO_MSK | ALTERA_AVALON_TIMER_CONTROL_CONT_MSK | ALTERA_AVALON_TIMER_CONTROL_START_MSK);
alt_irq_register(TIMER0_IRQ, 0, handle_timer_interrupt);
int main(){
printf("Hello from NIOS II \n");
uart_init();
printf("uart init successful");
timer_init();
printf("timer init successful");
//usleep(1000000);
printf("Hello from NIOS III \n");
*LEDs = 0xAA;
printf("Switch Status : %x " , (char)*Switches);
uart0_put_str("Hello World");
while(1){
//*LEDs = *Switches;
printf("hello");
return 0;
Isaac
- Isaac_V_Intel
Contributor
while(*str){
str++;
*LEDs=(char)data;
void uart_init()
alt_u32 control;
}else{
value = value + 1;
*LEDs=(char)value;
void timer_init(){
int main(){
uart_init();
timer_init();
//usleep(1000000);
*LEDs = 0xAA;
while(1){
printf("hello");
return 0;
Isaac
- Isaac_V_Intel
Contributor
Hi Junbun,
Did the code works for your issue?
Isaac.
- jpark198
I solved this problem and closed it, but it doesn't seem to close.
