22 years ago
uart help?
hardware:apex20K200E
software:quartus+sp1+nios
I want to receive the message access the uart .The information is attained by Simense GSM module.Please correct the code as follows:
//#include "buffer.h" // defines RXBUFSIZE and TXBUFSIZE# include <stdio.h># include "excalibur.h"# include "nios.h"
# define RXBUFSIZE 256
//#define TXBUFSIZE 256
//Global variables
unsigned char RxBuf[RXBUFSIZE]; // the receiver buffer.
int RxHead = 0; // the circular buffer index
int RxTail = 0;
//unsigned char TxBuf[TXBUFSIZE]; // the transmit buffer.
//int TxHead = 0; // the circular buffer index
//int TxTail = 0;
void simpleReceiver1(int context);
unsigned char _getchar();
void MyPIO_ISR(int context);
int main(void)
int context = 0;
int bidir_port_to_and_from_the_led_pio[1];
unsigned char rxchar;
np_pio *pio = na_led_pio;
nr_installuserisr(na_uart1_irq, simpleReceiver1, context); // install UART ISR (receiver)
na_uart1->np_uartcontrol = np_uartcontrol_irrdy_mask; // enable rrdy interrupt
while(1)
rxchar = _getchar();
printf("\nfrom RxBuf: %c \n",rxchar);
nr_installuserisr(na_button_pio_irq,MyPIO_ISR,(int)pio);
pio->np_pioedgecapture = 0; // clear any existing IRQ condition
pio->np_piodirection = 0; // all input
pio->np_piointerruptmask = 0xff; // they all generate irq&#39;s!
// bidir_port_to_and_from_the_led_pio[1]=1;
return 0;
// pass an int to make it compatible with nr_installuserisr2 routine
// contents of third argument ("context") in nr_installuserisr is passed to ISR
void simpleReceiver1(int data)
// put new char into buffer from UART
RxBuf[RxHead] = na_uart1->np_uartrxdata;
// clear the errors and interrupts
na_uart1->np_uartstatus=0;
if ((++RxHead) > (RXBUFSIZE-1))
RxHead = 0;
//receive _getchar
//Global variables
//unsigned char RxBuf[RXBUFSIZE]; // the receiver buffer.
//int RxHead; // the circular buffer index
//int RxTail;
unsigned char temp;
while (RxTail == RxHead)
nr_delay(1);
temp = RxBuf[RxTail];
if (++RxTail > (RXBUFSIZE -1))
RxTail = 0;
return(temp);
np_pio *pio = (np_pio *)context;
char s[256]; // a string
pio->np_pioedgecapture = 0; // clear the irq condition
