UART gets stuck when enabling IRQ (NIOS II)
Hi
Sorry for the slow response.
Kept going through your code and it looks fine.
I found out that you are accessing the JTAG UART.
It is slightly different from the UART IP.
The control registers are different compared to the UART IP.
https://www.intel.com/content/www/us/en/docs/programmable/683130/24-1/control-register-17391.html
Could you try the following code to register the interrupt ?
sp->irq_enable = ALTERA_AVALON_JTAG_UART_CONTROL_RE_MSK;
IOWR_ALTERA_AVALON_JTAG_UART_CONTROL(sp->base, sp->irq_enable);
alt_ic_isr_register(irq_controller_id, irq, altera_avalon_jtag_uart_irq, sp, NULL);
Jingyang, Teh
- Vincent_F2 years ago
Hi Jingyang, Teh,
No worries, we're all busy.
Thanks for your reply! Yet, the problem has nothing to do with the JTAG UART (i.e. the IRQ for this IP is never registered nor unregistered) I use it as my stdio interface.
The problem occurs on the RS232 UART (RFS2 UART in my project), i.e. when I enable/disable the IRQ on this interface.
Best regards
Vincent
