Hi @Patrik78 ,
Expert feedback:
Example flow for data transmitted (assuming stick parity not enabled):
Data
Even Parity (Tx)
Even Parity (Rx)
0x55
0101 0101 + 0 (check bit ‘0;’ because even par)
0101 0101 + 0 (checked bit ‘0’)
0x57
01010111 + 1 (check bit ‘1;’ because even par)
01010111 + 1 (checked bit ‘1’)
Data
Odd Parity (Tx)
Odd Parity (Rx)
0x55
01010101 + 1 (plus bit ‘1;’ because odd par)
01010101 + 1 (checked bit ‘1’)
0x57
01010111 + 0 (plus bit ‘0;’ because odd par)
01010111 + 0 (checked bit ‘0’)
(Since Stick parity is enable, parity does not depend on data):
Data
Even Parity (Tx) (SP=1, EPS=1, PEN=1)
Odd Parity (Rx) (SP=1, EPS=0, PEN=1)
Error
0x55
01010101 + 0 (plus bit ‘0;’ because even par)
01010101 + 0 (checked bit ‘0’)
Should get an error because Rx data is even parity
0x57
01010111 + 0 (plus bit ‘0;’ because even par with stick par)
01010111 + 0 (check bit ‘1;’ because even par)
Should not get an error because Rx data is odd parity
***The receiver side it will only check, the parity bit addition will be at the transmitter side only.
Both transmitting and receiving UARTs recommended to be configured same parity, either even or odd.
Recommended not to use the Stick Parity to 1, since the parity bits will be set, it will not be dependent on the data transmitted.
Sheng
