Patrik78
3 years agoUART 16550 IP - Stick parity problem
in my company we're facing a problem while using UART 16550 IP in stick parity mode: on LSR register we set SP=1, EPS=1, PEN=1 in order to use MARK_PARITY.
While in transmission everything...
ShengN_altera
3 years agoHi,
You say that the LSR register bit 2 (PE) sometimes is "0" and sometimes is “1”. So when Parity Error (PE) bit is "0", does the Break Interrupt (BI) bit being triggered? If the Break Interrupt (BI) bit is not triggered, then the Parity Error (PE) bit is "0" that's expected.
