Patrik78
3 years agoUART 16550 IP - Stick parity problem
in my company we're facing a problem while using UART 16550 IP in stick parity mode: on LSR register we set SP=1, EPS=1, PEN=1 in order to use MARK_PARITY.
While in transmission everything...
ShengN_altera
3 years agoHi,
This is the expected behavior based on document. The SP bit works in conjunction with the EPS and PEN bits. Means SP bit is more passive and it depends on EPS & PEN bits. So at receiving, when even parity is selected (EPS = 1), the PARITY bit (SP) is checked as cleared. When odd parity is selected (EPS = 0), the PARITY bit (SP) should be checked as set.
Sheng
