Patrik78's avatar
Patrik78
4 years ago
UART 16550 - 9 bit mode
I started working with this IP, and reading embedded user guide I can see it is 5-9 bit character length configurable.
In fact LCR register bit number 8 (dls9) can be used to configure a 9 bits character length.
But the user guide does not explain how to read/write the 9 bits character.
RBR/THR register is written to be only 8 bit length in table 75 ... can I assume that in case of 9 bits configuration RBR/THR is 9 bit readable/writeable ?
  • ctavoni's avatar
    ctavoni
    I have the same problem trying to use the 16550 IP to emulate the 9th bit "wake up mode" (68hcxx) or the "multiprocessor communication Mode 2" (i8051)
    I can understand that Stick Parity is activated to "0" if LCR [5]=1 and LCR [3,4]=11, and is activated to "1" if LCR [5]=1 and LCR [3,4]=10 so is clear what happen in the Tx process.
    In the Rx process is not clear:
    1. where I can read the Rx Stick Parity Bit?
    2. can be associated a "Parity Interrupt" to a specific value of the Stick parity bit and how?
    Best Regards
  • aikeu's avatar
    aikeu
    Hi Patrik78,
    I will consult engineering side regarding this matter on that particular IP.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi Patrik78,
    Sorry for the late reply.
    The rbr_thr_dll in the user guide should be updated to 9 bit.
    rbr and thr uses 9 bit while dll uses 8 bit when referring to the system verilog code of the IP.
    As for stick parity(SP), is used to set for TX and RX as well.
    Inside ier_dlh Fields:
    ier_dlh[2] interrupt enable for receiver line status (includes parity error status)
    Aik Eu
    • Patrik78's avatar
      Patrik78
      Dear Aik,
      thanks for the answer.
      When do you think we could have an update of the "Embedded Peripherals IP User Guide" (ID: 683130, Version: 2022.06.21) that include the 9th bit use in the rbr_thr_dll (chapter 10.4.1) ?
      In my company we have internal rules that does not allow to use any functionality not present in official documents.
  • aikeu's avatar
    aikeu
    Hi Patrik78,
    I will close this thread if no further question.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi Patrik78,
    I will file a HSD internally for the update required in the Embedded peripherrals document.
    Will let you know if there is an expected date for the changes to be done.
    Aik Eu
    • Patrik78's avatar
      Patrik78
      Hello Aik,
      Please consider we would need to have these informations by mid-October.
      We are in a critical project phase.
      Thanks again for your help.
  • aikeu's avatar
    aikeu
    Hi Patrik78,
    At the moment, there is no estimated time yet. I will try to push for the changes asap.
    Anyway I will contact you through email regarding this further and will close this thread for now.
    Aik Eu
