11 years agoU-Boot for Nios2 on DE2-115 Board with MMC/SPI support
Hello again, i am trying to compile U-Boot for my DE2-115 board. I was able to compile U-Boot and run it on the Board, but now I want to add MMC/SPI support. I added: # define CONFIG_C...
11 years agoJan
I am trying to build Uboot for Nios2 also. No luck but I have learned a few things. Uboot configuration for nios2 has changed significantly. The Alter-Wiki is way out of date. It didn't work for me either. There is a special git repo for nios2 at git://git.denx.de/u-boot-nios.git. Uboot is moving to Kconfig and Make files - i.e. "boards.cfg" is deprecated. This explains why I did not find "boards.cfg" after git cloning. I tried the following on Linux bash. > git clone git://git.denx.de/u-boot-nios.git > cd u-boot-nios/ > make menuconfig These proceeding steps complete with no visible errors or warnings. Make menuconfig has a lot of configuration options - it may support what you are trying to do. You can also run > make config and you'll get many, many configuration choices. Then I run > make all This step fails for me with the following error LD arch/nios2/cpu/built-in.o /bin/sh: nios2-elf-ld.bfd: command not found scripts/Makefile.build:354: recipe for target 'arch/nios2/cpu/built-in.o' failed make[1]: *** [arch/nios2/cpu/built-in.o] Error 127 Makefile:1037: recipe for target 'arch/nios2/cpu' failed make: *** [arch/nios2/cpu] Error 2 I confirmed that both 'nios2-elf-gcc' and 'nios2-elf-ld' are in the path and are executable. And since I have been running Nios2 successfully on Linux this should indicate my 'nios2-elf-gcc' and 'nios2-elf-ld' should be OK. It appears the compile completed but the nios2 linker is not found. Just a heads-up that have been some big changes for the steps required for building Uboot for nios2. Sorry, but I have not found any up-to-date build instructions either. Dave
