16 years agoU-Boot DIV64 Issue
I just made u-boot works with Ethernet and Flash access and try to boot the linux kernel. but there is an error exception.
--- Quote Start --- ==> imi e8060000 # # Checking Image at e8060000 .... Legacy image found Image Name: test Image Type: NIOS II Linux Kernel Image (uncompressed) Data Size: 3371311 Bytes = *** ERROR: unimplemented instruction @ c7fd5764# ## ERROR# ## Please reset board# ## --- Quote End --- after tracing the code, i found the error is caused by an 64bit-divide-64bit operation. display_options.c in u-boot/lib/ --- Quote Start --- void print_size(unsigned long long size, const char *s) { unsigned long m = 0, n; static const char names[] = {'E', 'P', 'T', 'G', 'M', 'K'}; unsigned long long d = 1ULL << (10 * ARRAY_SIZE(names)); char c = 0; unsigned int i; ... n = size / d; <=== error generated here ... --- Quote End --- Since there is no any warning/error message during u-boot compile. Does anyone have any suggestion ?12 Replies
I think kernel toolchain may be linking in glibc code for the div64 function. I don't know why the glibc code doesn't work in U-Boot (or why this would suddenly change).
I ran in to something similar with mul64 recently. I worked around it by implementing my own mul64, so it wouldn't try to link in the glibc version. - Altera_Forum
Pinta, thanks for the clue.
jhwu0625, I added gcc4 support, please pull. - Hippo
