TSE on Arria10 and marvell88e1512
Have you also tried the same design with the MicroC/OS-II with simple socket server template on you custom board?
Example Refence link is given below-
Tiwari
- MatC2 years ago
Thanks for the replay.
I'm using quartus 22.4 and the suggested example is no longer supported.
To test the example on my board I had to use Quartus 18.0 and it works fine.
At this point I have also tested my firmware with Quartus 18.0 and it works fine. One of the biggest differences I noticed is the packet length, for example the TSE in Quartus 22.4 does not pad the packet correctly, in fact the shortest packet I can see in Wireshark is 56 bytes long, the same packet sent with TSE 18.0 is 60 bytes long, in general to get the right packet length I have to add +4 to the packet length. At this point I have a question: Is there a different configuration I need to consider when configuring the newer TSE version?Thanks in advance
