11 years agoTrigonometric functions with FPU
Hello, I'm trying to reduce the latency of my arithmetic operations. For that purpose i The CUSTOM FPU INSTRUCTION to my Nios. I've enabled HW and DIV at NIOS2-F. Using this Custom Instructi...
11 years agoThank you dsl & mikedsouze for your answer.
@dsl: --- Quote Start --- you ought to be able to compile the trig function library routines to use the custom instructions internally. --- Quote End --- How can I do that ? @mikedsouze : --- Quote Start --- reason is that i have a feeling that the compiler is unable to map the new operations to the newlib. you could try to recompile newlib, rebuild bsp folder. --- Quote End --- I have a newlib generated with the BSP but it's empty. Is there any configuration special to do in eclipse to recompile newlib ? Sorry for wasting your time. Best regards
