14 years agoTransferring data from a HDL to the Nios II processor
I have a HDL module which is connected to the Avalon bus as a slave component. The component has a FIFO with a length of 4096 * 32 bits values which the processor should read out perdiodically. The processor should always read from the same address. According to: http://www.altera.com/literature/tt/tt_nios2_tightly_coupled_memory_tutorial.pdf I should use the IORD macro to read out the data. The following questions are bothering me: 1. I haven't quite understood why using a pointer to the device address (e.g. int32_t *module_data = MODULE_BASE) won't work. Why does it work for memory (like DDR RAM attached to the processor) but not for a memory mapped device attached to the Avalon bus? 2. Is it possible to use a DMA controller to do the data transfer (is generally possible, e.g. if I would change the module so that every word has its own address)? Transferring the data using only the IORD macro would probably eat a lot of CPU cycles. Best regards Martin12 Replies
Yes, but as explained in this previous post: http://www.alteraforum.com/forum/showthread.php?t=33460&p=167183#post167183 I've implemented another solution.
can you send your top file to me?how the dual port RAM worked,and the data from avalon bus to nios,the IORD is the only way?have something other ways to read the data from Avalon Bus with less CPU circuits?can you help me?
