16 years agoThere is a problem when I transplanted uClinux to DE3(EP3SJ150F1152C)
Hi,everyone.I have a DE3 board(EP3SL150F1152C).I want to transplant uClinux to the board.I do followed the www.nioswiki.com (http://www.nioswiki.com). I use the DE3_demonstrations in the DE3_v.2.2_CD...
16 years agoHi
I just search for this solution as well just now. Before this i have ported uclinux on the stratix II developement board. I took the DE3_150_DDR2_1G_1RANK reference design from the de3 system design cd and try port uclinux on that system. First problem i encounter is that the nios2-terminal hang after this display on the terminal: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB 4-1.2]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Then i checked the system design again and found that the cpu reset vector and Exception vector are on onchip_mem Then I disable the onchip_mem and connect the cpu instruction master and data master to the altmemddr which is the high performance DDR2 SDRAM. Then i reconfigure the cpu reset vector and exception vector to altmemddr, regenerate and recompile the design. After all the configuration, the uClinux amazingly boots up. :D hope this helps.
