10 years agothe "signed" type i/o in vhd file disapear when i try to add my new component
hi every one; i write my own component in vhd and try to add it in qsys, in the component editor, i and my vhd file and click analyze files, it shows 0 errors and 0 warnings. but in the signal...
10 years ago --- Quote Start --- hi every one; i write my own component in vhd and try to add it in qsys, in the component editor, i and my vhd file and click analyze files, it shows 0 errors and 0 warnings. but in the signals & interfaces tab, i can not find the "signed" i/o in vhd files like: S_encoder1_Z_reg_out : out STD_LOGIC_VECTOR(1 downto 0); S_encoder1_AB_for_interpolation_reg_out : out STD_LOGIC_VECTOR(1 downto 0); S_encoder1_period_counter_reg_out : out signed(31 downto 0); the "signed" signal does not appear in signals & interfaces tab, the std_logic and std_logic_vector signals are ok how can i fix this? should i have to change the signed to std_logic_vector? --- Quote End --- Prefered method to describe external interface for module - std_logic_vector and in implementation you can use casting to or from another type. Hope this problem not due optimisation when CAD rename or even remove unused ports. Perhaps if std_logic_vector works for you then you can use workaround :
entity BlaBlaBla is port ( S_encoder1_period_counter_reg_out : out std_logic_vector (31 downto 0 )); end BlaBlaBla;
architecture v of BlaBlaBla is
signal S_encoder1_period_counter_reg : signed (31 downto 0 );
begin
S_encoder1_period_counter_reg_out <= std_logic_vector(S_encoder1_period_counter_reg);
end v;
