21 years agoThe performance of simple socket server
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif I need to transfer a lot of data from PC to the 1c20 board . So, I try to modify the simple socket server project w...
15 years ago --- Quote Start --- I have done the same. Since you probably do not send packets both ways (mostly TO the board), lwip waits for outgoing packets for some time before it ACKs a packet. You need to change the timeout for this counter, and you should also send an immediate reply for each packet. Do the following in \altera\kits\nios2\components\altera_lwip\UCOSII\src\downloads\lwip-0.6.3\src\api\tcp.h: # define TCP_FAST_INTERVAL 100 You should try other values as well. Also, in tcp.c, change tcp_recved() to: void tcp_recved(struct tcp_pcb *pcb, u16_t len) { int ackNow=0; if ((u32_t)pcb->rcv_wnd + len > TCP_WND) { pcb->rcv_wnd = TCP_WND; } else { pcb->rcv_wnd += len; ackNow=1; } if (!(pcb->flags & TF_ACK_DELAY) && !(pcb->flags & TF_ACK_NOW)) { /* * We send an ACK here (if one is not already pending, hence * the above tests) as tcp_recved() implies that the application * has processed some data, and so we can open the receiver's * window to allow more to be transmitted. This could result in * two ACKs being sent for each received packet in some limited cases * (where the application is only receiving data, and is slow to * process it) but it is necessary to guarantee that the sender can * continue to transmit. */ tcp_ack(pcb); }else if((pcb->flags & TF_ACK_DELAY)&&(ackNow)){ //++cg[11/10/2004]: I think this is what Atte Kojo was talking about tcp_ack(pcb); } } --- Quote End --- Hello, I am using Quartus II version 10.0sp1. I did not found the# define and the function you mentioned. Can you advice me how can I achieve better data rates using TCP and simple socket server. Your prompt response is highly appreciated. Thanks & Regards
