21 years agoThe performance of simple socket server
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif I need to transfer a lot of data from PC to the 1c20 board . So, I try to modify the simple socket server project w...
21 years agoI have done the same. Since you probably do not send packets both ways (mostly TO the board), lwip waits for outgoing packets for some time before it ACKs a packet. You need to change the timeout for this counter, and you should also send an immediate reply for each packet.
Do the following in \altera\kits\nios2\components\altera_lwip\UCOSII\src\downloads\lwip-0.6.3\src\api\tcp.h: # define TCP_FAST_INTERVAL 100 You should try other values as well. Also, in tcp.c, change tcp_recved() to: void tcp_recved(struct tcp_pcb *pcb, u16_t len) { int ackNow=0; if ((u32_t)pcb->rcv_wnd + len > TCP_WND) { pcb->rcv_wnd = TCP_WND; } else { pcb->rcv_wnd += len; ackNow=1; } if (!(pcb->flags & TF_ACK_DELAY) && !(pcb->flags & TF_ACK_NOW)) { /* * We send an ACK here (if one is not already pending, hence * the above tests) as tcp_recved() implies that the application * has processed some data, and so we can open the receiver's * window to allow more to be transmitted. This could result in * two ACKs being sent for each received packet in some limited cases * (where the application is only receiving data, and is slow to * process it) but it is necessary to guarantee that the sender can * continue to transmit. */ tcp_ack(pcb); }else if((pcb->flags & TF_ACK_DELAY)&&(ackNow)){ //++cg[11/10/2004]: I think this is what Atte Kojo was talking about tcp_ack(pcb); } }
