15 years agoThe Highest Carrier Frequency for Stratix III
Dears All, Greetings, I was just wondering about how high I can get as an output from the the Stratix III Development Kit as a carrier frequency. I know I can use two ways to generate that...
15 years agoI already have the part of mixing the signal with the 3GHz solved I had the output from the two HSMC outputs.
but, I didn't really get what you mentioned about converting to analog signal first .. because the case is to have the up converted signal inside the FPGA before it is sent to the HSMC output. Thanks,
