Michael2021
1 year agoThe error message is as follows: "nios2-bsp-update-settings : command not found"
I downloaded the A10_DP_RX_FMC_PRO.par file and compiled it with Quartus Pro 19.2. AN 900: Intel® Arria 10 DisplayPort 8K RX-only Design Link: https://www.intel.com/content/www/us/en/docs/programma...
Michael2021
1 year agoHi BB,
While running build_sw.sh in the nios2 command shell, the following error occurred:
make: nios2-elf-gcc.exe: No such file or directory.
I've attached three screenshots of this issue.
Please help me resolve this issue.
Michael
Michael2021
1 year agoThe actual directory contains "H-x86_64-mingw32", but the path only contains "H-i686-pc-linux-gnu".
Is this error related to this issue?
- AdrianaI_Altera1 year ago
Hi @Michael2021
That issue was solved in this Forum thread: https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/nios2-elf-gcc-exe-error-CreateProcess-No-such-file-or-directory/td-p/1203392
- Michael20211 year ago
works good.
Thank you
