15 years agoTcl scripts with Nios II BSP Editor
I'd like to pass a custom Tcl script to nios2-bsp to modify the linker memory regions, just like Example 4-1 in the Nios II Software Developer's Handbook. How do I do that if I'm using the GUI and the NIOS II BSP Editor? Specifically, where do I tell the GUI that it should look for my Tcl script?
I don't want to specify the entire BSP with a Tcl script, just modify it after the default script runs. On the command line I would do something like this: 'nios2-bsp hal my_bsp --script my_script.tcl". I did find some documentation that claims I can do this through a "New BSP Settings File" dialog box, but I have never seen that box. If this is in the documentation somewhere and I missed it, please let me know. Thanks. P.S. Is there a good way to debug these scripts? I'm new to Tcl, so I'm kind of guessing at how it should work at times.1 Reply
In order to keep making progress, I'm working on the script with the command line tools. I've noticed that nios2-bsp will give me the following message: "Default memory regions will not be persisted in BSP Settings file." Why?
For reference, my goal is to look for a memory region. If it's not there, I split an existing region into two. If it is there, I do nothing. What I'm finding is that most of the time I lose all of the default memory regions when I run nios2-bsp and I don't understand why.
