14 years agoSystem Console & master_write_32 — can't do this while target is running?
I had a simple controller written in Verilog that was configuring Altera's TSE MAC. Up to this point, it was fairly simple. However, what I wanted to do next is to set a lot of Marvel PHY's settings ...
14 years ago --- Quote Start --- The other option, if you do not want to stop the CPU, is to put the jtag to avalon master bridge. You can find it in bridge section of the component library list. --- Quote End --- :confused: That's exactly what I said one post earlier... --- Quote Start --- A simple way that fits you needs of configuring the MAC + PHY is to add a "JTAG to Avalon Master Bridge" component. --- Quote End ---
