15 years agosymbols in build configurations
I am using NIOS SBT 9.1, and I want to set up separate debug and release build configurations and have different global symbol defines for each configuration. However, if I define symbols in the C/C...
15 years agoI have also tried to find solution to this problem. It seems that there is no 'easy way' solution to conditional Build in NIOS 10.1 SBT .
See "Nios II Embedded Design Suite Release Notes and Errata" (These release notes cover versions 9.1 through 10.1 of the Altera® Nios® II Embedded Design Suite (EDS).) (page 34) unsupported cdt feature: paths and symbols alternative nios ii feature: use nios ii application properties and nios ii application paths Also I've defined my symbols there and live without conditional build.
