symbols and beats, quick clarification needed
are symbols parallell or serial within a beat?
You need to supply some context ....
okay, i am trying to determine which is the fastes way to send a 192 bit wide datastream from a receiver => dual clock fifo => to sdram using dma.
setup 1: using mm interfaces and 2x fifo and DMA, and splitting the stream into one 64 bit wide and one 128 bit wide "channel". setup 2: using ST interfaces and configuring one fifo and one sgdma for (x bits pr symbol)*(y symbols pr beat) = 192 datawidth. - Altera_Forum
there is no doubt that streaming interface with sgdma is faster.
in streaming interface, there are: one beat per clock, one or some symbols per beat, one or some bits per symbol. the bit width of data signal equals to bitpersym*symperbeat. the bit width of empty signal, which assert when endofpkg is high to indicates how many useless symbols are there in the last beat of a package, equals to ceiling(log2(symperbeat)). - Altera_Forum
thanks. can the sgdma "scatter-gather" from three 64bit sources and put in the sgdma** in one cycle?
** meant sdram - Altera_Forum
you mean using 3 sgdmas? it's a waste of area, and if you do so a 192 bit data will be split into 3 parts stored in different areas of your memory.
I think you can use a data_format_adaptor: 64 bitpersym * 3 symperbeat => data_format_adaptor => 64 bitpersym * 1 symperbeat => sgdam with 64-bit data width. - Altera_Forum
I was thinking about three fifos, and one sgdma to transfering 3*64 bits each beat. altough i doubt it can (no experience with dma's). i will look into data_format_adaptor, but ideeally i would like to be able to transfer the whole 192 bits each clockcycle.
I'm not sure of the write rate you'll get to the SDRAM, but it is unlikely to sustain one 32bit word per clock - although you might get bursts of that.
I don't think you can put a 64bit interface on the SDRAM block? This probably means that you need to build your own fifo. - Altera_Forum
okay i should have thought of that. when i configure the sgdma (that writes to sdram), i can set datawidth to 64 without getting any errors in sopc-builder. does that mean it splits the 64 bits into two writes then?
Not sure, but you might end up with a generic 'bus width adapter',
and, if you aren't careful, a clock crossing bridge. Unfortunataly the sopc builder doesn't tell you when it adds either of these. - Altera_Forum
what would the bus width adapter do? discard all but 32 bit or split the write over more cycles?
