15 years agoSupport JIC file for Parallel NOR
Hi, Altera has something called a JIC file that can combine the FPGA and software into one file and it is designed for a serial flash only i guess. How do we support for Parallel NOR Flash? ...
15 years agoJIC (JTAG indirect configuration) files are used for both serial and parallel flash. As far as I know, there's no difference regarding serial or parallel interface.
P.S.: In the Convert Programming File tool, you can select all memory device parameters and options for both JIC file variants.
