veex-tmiller
4 years agoStruct Assignment from function not working.
In my code I am attempting to return a struct from a function for assignment to another struct. It is in the general form of :
typedef struct WaterMarkStats_t{ unsigned int MarkBegin; unsigned in...
hareesh
4 years agoHi Rodney Miller,
Since I had provided you the solution/answer and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
I shall set this case to close pending,
If you happened to close this case you will receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Hareesh B.
