21 years agoStreaming DMA UART
Quartus II Version 4.00 SP1 Full Version Nios II Version 1.0.0 (With SP1) I'm trying to create a very simple system of streaming characters from memory UART using the DMA. The purpose is...
20 years agoi try to use your code successfull .
After i use structure data instead buffer of bytes . So in this case the dma continually send butes and my pc became crazy . Then i try to fill your buffer from my data structure but the same occur . http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Very strange In pc side i'm using vc#.net with a rs232 dll . I post my code # include <stdio.h># include <stdlib.h># include "sys/alt_dma.h"# include "system.h"# include "alt_types.h"# include "dma_test.h" typedef struct conn{ alt_u16 data1; alt_u16 data2; alt_u16 data3; alt_u16 data4; }Master; alt_u8 buffer[16] __attribute__ ((section (".ext_ram"))); Master data;// __attribute__ ((section (".ext_ram"))); static volatile int dma_complete = 0; void dma_done (void* handle) { dma_complete = 1; } int main(int argc, char* argv[], char* envp[]) { int rc; //buffer[0] = 0x30; //buffer[1] = 0x31; //buffer[2] = 0x32; //buffer[3] = 0x33; data.data1=10; data.data2=20; data.data3=30; data.data4=40; data.data5=50; data.data6=60; data.data7=70; data.data8=80; alt_u8 i; alt_u8* pDati; alt_u8 size = sizeof(data); pDati = (alt_u8*)&data; //Point the first byte of my structure for(i=0; i< size; ++i) { buffer[i] = *(pDati+i); } void* tx_data = (void*) &buffer[0];//data;//&buffer[0]; printf("Hello from Nios II!\n"); printf("size:%u\r",size); alt_dma_txchan tx; if ((tx = alt_dma_txchan_open("/dev/dma_0")) == NULL) { printf("Failed to open device!\n"); exit(1); } alt_dma_txchan_ioctl(tx, ALT_DMA_SET_MODE_8, NULL); alt_dma_txchan_ioctl(tx, ALT_DMA_RX_STREAM_ON, (void*) UART_0_BASE+1); dma_complete = 0; if ((rc = alt_dma_txchan_send (tx, tx_data, 16, dma_done, NULL)) < 0 ) { printf("Failed to post transmit request!, reason = %i\n", rc); exit(1); } while (!dma_complete); alt_dma_txchan_close (tx); printf("Transaction Complete!\n"); printf(" :%u,%u,%u,%u,%u,%u,%u,%u\r",buffer[0],buffer[1],buffer[2],buffer[3],buffer[4],buffer[5],buffer[6],buff er[7]); return 0; } The last printf i use prints the correct value of 16 bytes buffer . But the pc receive totally differents datas. Printf shows to me correct data in buffer : buffer[0]=10 buffer[1]=0 buffer[2]=20 buffer[3]=0 ............ in the pc i recevice 58-58-10-30-58-58-10-30-58-58-10-30-58-58-10-30 Do you have some idea? ciao walter
