15 years agoStratix III DSP Board flash programming issue
Hi all !
I have a problem with the flash programming of the stratix III based DSP Board. I want to store in the CFI flash memory ( PC48F4400P0VB00 ): -The FPGA configuration file, -The software project, -The .zip file. All of these files are related to the web server appllication. The purpose is to configure the FPGA and run the software when the board is powered on but I don't succeed in. I was searching and reading the flash programmer ug and some other documentation (this forum, Nios wiki,...) but I still don't understand how to make it. I know hardware design must be programmed in specified region of the flash but I don't know what it is. Indeed, I don't find an exact information telling me the adress where these FPGA files must be programmed as well as the software project and the .zip file. I know the reset vector of the NiosII must be located in the flash in order to be able to copy the software in the ram located on the board. I have joined the SOPC memory mapping screenshot as well as the screenshot of the CPU configuration. To program the flash, I have used the flash programmer included in Nios II IDE. Quartus II and NIOS II IDE version : 9.0 sp2. If you have questions, please let me know, Best regards, Jeremy.No RepliesBe the first to reply
