15 years agoStrange Ethernet behaviour
We currently have a a design which is based heavily upon the Cyclone 3 FPGA dev kit. However, at this point it is very difficult to return to the Dev Kit to test the software some am hoping someone h...
15 years agoThanks for you help, We'll have a closer look at the timings around the SGDMA and the Memories to see what is happening there.
We do have a couple of timing warnings in the system so maybe clearing these up might reduce the need for the modification to Rx Timing delays. I have another question though which might well be semi related to these problems. I have found that when a something connects and disconnects rapidly i begin to see the "No free buffers for rx" and this then repeats and eventually crashes the system. I have looked for this on the forum but not found anything that matches my symptons. Have you seen this or have any ideas. I cannot really see why it keeps requesting RX buffers. Although i do try and send as soon as the connection is made. Perhaps i should have some stable time to ensure it doesnt disconnect on me. Cheers Tim
