15 years agoStrange Ethernet behaviour
We currently have a a design which is based heavily upon the Cyclone 3 FPGA dev kit. However, at this point it is very difficult to return to the Dev Kit to test the software some am hoping someone h...
15 years agoThis could be similar to the problem I found and described in the previous post.
System behaviour changed completely when I added or removed delays. For example the connection worked fine if a hub or switch was inserted between server and client, failed if I connected directly. Same if I artificially delayed tx or rx frames. As I told you, this was related to the concurrence of tx and rx data in sgdma.
