15 years agoStrange Ethernet behaviour
We currently have a a design which is based heavily upon the Cyclone 3 FPGA dev kit. However, at this point it is very difficult to return to the Dev Kit to test the software some am hoping someone h...
15 years agoDo you have a point to point connection or are you connected to a LAN?
DHCP or fixed IP? I don't know if your case could be related to this: Last year I had a problem with iniche+tse: in presence of concurrent tx and rx, some frames were lost. If tx and rx were not overlapped there was no problem. After long investigation, I discovered the problem was in sgdma driver: sometimes rx and tx frames got corrupted because dma data was allocated in the same memory area. I never found if I myself was making some error or if this is an undocumented driver bug: if you use TCP this behaviour is somehow hidden, since TCP would recover the lost frames and you get only a minimal performance loss. I only needed 100Mbps, so I solved the problem using the opencores mac in sync mode.
