15 years agoStore SW-Program and Data on CFI-Flash
HI there! I am running a Nios II - system on a DE0-board from Terasic. The flash programmer has successfully programmed the software into my flash memory. I am currently trying to save (non vol...
15 years agogabrigob,
Thanks once again. I took a look at that document and you were very right :) It was helpful and also linked me to other documents. " Altera provides example boot loaders for CFI and EPCS memory in the Nios II EDS, precompiled to Motorola S-record Files (.srec). You can use one of these example boot loaders, or provide your own. " Cheers, mr_embedded
