21 years agoSRAM vs SDRAM
Hi, I am about to design a system with uClinux, and I was wondering if the performances would be correct if I only used an SDRAM. SRAM is a bit expensive if I want to have enough memory to run...
20 years ago> do you use a 16 bit or 32 bit external databus to the psram ??
16-bit --Scott
