21 years agoSRAM vs SDRAM
Hi, I am about to design a system with uClinux, and I was wondering if the performances would be correct if I only used an SDRAM. SRAM is a bit expensive if I want to have enough memory to run...
21 years agoDear Scott,
may I ask you what PSRAM you use (manufacturer) and what amount of memory I need to run a linux properly ? Thanks a lot cetic
