19 years agoSPI RX problems
Hi I am trying to receive data via SPI on the Nios II using a Cyclone II. The Nios is the slave and the SPI master transmits data at 2MHz. I have tested transmitting data from the Nios ...
19 years ago --- Quote Start --- originally posted by ashish@Dec 30 2006, 09:05 AM dear ericbaker,
looks we are working on the same project. i have to built a spi slave using nios2 and test the correct working of the spi master which i've build on max2 cpld. can you help me with the nios programming? can we use spi core available under avalon components?
thanks,
ashish
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20293)
--- quote end ---
--- Quote End --- Hi Ashish I've been away on holiday... Yes, you should be able to use the altera spi core. Set it up as a slave and use the sample code provided by altera. I guess this info comes to late...
