19 years agoSPI RX problems
Hi I am trying to receive data via SPI on the Nios II using a Cyclone II. The Nios is the slave and the SPI master transmits data at 2MHz. I have tested transmitting data from the Nios ...
19 years agoDear EricBaker,
looks we are working on the same project. I have to built a spi slave using nios2 and test the correct working of the spi master which I've build on max2 cpld. can you help me with the nios programming? Can we use spi core available under avalon components? Thanks, Ashish
