Evelyn412's avatar
Evelyn412
4 years ago
sopc-create-header-files: Failed writing output file to /tmp/sopc-create-header-files.206.tmp.swinfo
I update quartus project from 18.1 standard to 20.1.1 standard version. When I use sopc-create-header-files tool to generate the header file for the Qsys system, there is a mistake: Failed writing output file to /tmp/sopc-create-header-files.206.tmp.swinfo sopc-create-header-files: sopcinfo2swinfo.exe --input=./top.sopcinfo --output=/tmp/sopc-create-header-files.206.tmp.swinfo failed (There is no problem when I use the 18.1 standard version) Hope anyone knows can help me, thanks a lot.
  • Evelyn412's avatar
    Evelyn412
    Hi aikeu, the link to github can not be found now, and I have tried another way in your link, it is not helpful.
    And I figured out that if I delete the /tmp/ folder in the sopc-create-header-files script file, it is OK now.
    (change from swinfo_tmp_fname=/tmp/${PN}.$$.tmp.swinfo to swinfo_tmp_fname=${PN}.$$.tmp.swinfo)
    It seems like that there is no permission to create the tmp folder.
    ps: I don't know why I cannot reply you before, the reply button is always grey...
  • aikeu's avatar
    aikeu
    Hi Evelyn412,
    Any follow up from the previuos comment?
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi Evelyn412,
    I will close this thread if no further question.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi Evelyn412,
    Aik Eu
    Evelyn412
  • JoshF's avatar
    JoshF
    Thanks Evelyn, this worked for me!
