9 years agosopc-create-header-files : command not found ?
hi,
iam an beginner in fpga soc.... i try the tutorial "my_first_hps_fpga.pdf" .... so i have an problem to generate header files about embedded command shell... if i want to execute the bash-file ./generate.sh... generate.sh: # !/bin/sh sopc-create-header-files "./hps_fpga.sopcinfo" --single hps_0.h --module hps_0 i get this message.. ./generate.sh: Line 3: sopc-create-header-files: Commando not found...:oops: http://www.alteraforum.com/forum/attachment.php?attachmentid=12978&stc=1 i hope somebody can help ... thx..5 Replies
If anyone else is getting this error, I have figured out the solution.
You have to set the PATH variable in the SoC EDS command shell The bin folder is located in the path: intelFPGA_lite\16.1\quartus\sopc_builder\bin you have to add this folder to the PATH environment in the SoC shell For example: PATH=/cygdrive/C/intelFPGA_lite/16.1/quartus/sopc_builder/bin:$PATH You have to change the path to the correct one in your PC ;) - Altera_Forum
For linux :
lauch the Altera embedded script shell type : $echo $PATH to display the PATH environment variable. To add a path to this variable, use the command : export PATH=$PATH:~/intelFPGA_lite/17.1/quartus/sopc_builder/bin You need to have Quartus installed in addition of the EDS suite. - Altera_Forum
I have the same error.. I'm trying to create the "sopc-create-header-files" with the sopc builder but my efforts have been unsuccessfully. If you have another clue how we can fix it, please tell me... thx..
Using 16.1 on Windows 10 I was able to run that command using both the SoC and Nios II command prompts. That command is part of Quartus install and you can find the path here: <Quartus install directory>/quartus/sopc_builder/bin/sopc-create-header-files
--- Quote Start --- If anyone else is getting this error, I have figured out the solution. You have to set the PATH variable in the SoC EDS command shell The bin folder is located in the path: intelFPGA_lite\16.1\quartus\sopc_builder\bin you have to add this folder to the PATH environment in the SoC shell For example: PATH=/cygdrive/intelFPGA_lite/16.1/quartus/sopc_builder/bin:$PATH You have to change the path to the correct one in your PC ;) --- Quote End --- Hi, I have located the bin folder in my laptop. However, after I add this folder to the PATH environment, it still does not work. The same error occurs. I am using quartus 15.0 web version and my SoC EDS is 17.0 version. Not sure whether different version of quartus and SoC EDS is causing this problem...
