9 years agosopc-create-header-files : command not found ?
hi, iam an beginner in fpga soc.... i try the tutorial "my_first_hps_fpga.pdf" .... so i have an problem to generate header files about embedded command shell... if i want to exe...
9 years agoUsing 16.1 on Windows 10 I was able to run that command using both the SoC and Nios II command prompts. That command is part of Quartus install and you can find the path here: <Quartus install directory>/quartus/sopc_builder/bin/sopc-create-header-files
