SOPC Builder reports missing DB9000 Avalon components, but Quartus compilation does not
Hi Kian,
Thanks for the response, I do see log files where the compilation was successful and sof and pof were generated, I had also contacted Digital Blocks team who supplied the DB9000 IP, they also confirmed what you mentioned, that I might be missing certain files needed for SOPC builder to yield successful build but a previous successful build can be used in Quartus Compilation.
"You can't change the system (add or remove components, or edit parameters) until SOPC Builder can load the DB9000 components again."
I am assuming you meant I cant modify the SOPC side design i.e involving NIOS, but I can modify the quartus design right, compilation would still use the successful build vqm available>
Kannan
Hi Kannan555,
Yes, that's what I meant. You can't change anything inside the SOPC Builder system. You can change the rest of the Quartus project, and compilation will keep using the existing .vqm and the generated system HDL.
You can change this like :
- Your top-level HDL and any custom logic outside the SOPC system.
- What connects to the SOPC system's exported ports, so long as the ports themselves stay the same.
- Pin assignments, I/O standards, timing constraints (.sdc), and other Quartus settings.
- Nios II application code, provided the hardware stays the same. Build against the existing .sopcinfo and board support package (BSP).
What you can't change without SOPC Builder:
- Anything inside the system: the Nios II processor, peripherals, the DB9000, memory map, interrupts, clocks, or the interconnect.
- The SOPC system's exported port list.
- The generated system HDL. Editing it by hand is technically possible, but it's risky and breaks the link to the SOPC design.
Things to watch when you change the Quartus side:
- Rerun timing analysis after every compile. Quartus re-places and re-routes everything, including the DB9000 logic from the .vqm. The DB9000 still works the same way logically, but its timing can change. Check that the SDRAM and LCD clock domains still meet timing.
- Don't regenerate. Don't open the system in SOPC Builder and click Generate. Keep the project pointing at the existing generated files, and keep a backup.
- On-chip memory contents. If Nios II code or data lives in on-chip memory initialized from a .hex file, a software change needs that file updated in the .sof/.pof. You can either recompile or use Quartus's update-memory-initialization step. Your existing compile logs will show which applies.
Kian
- Kannan55529 days ago
Thanks Kian
