15 years agoSOPC builder and DPRAM
High! I need to implement a dpram with AVALON on 1 side and a free access for an IP I already have. The avalon would be in a write only scheme and the IP in read only. But when I put an on chi...
15 years agoHi Cris72 and Daixiwen!
Thanks for your fast reply. Actually I've started implementing Daixiwen's solution. This because I've decided to put the whole IP as a custom peripheral. So the DPRAM is only a section of that. By the ways it's an I2S interface with a 2K samples buffer. Samples are streamed in and out by Ethernet. The IP has been used before on an Excalibur EPXA4! That was a good one! Good day to all of you Thomas
