14 years agoSOPC builder - connect a custom component to tightly coupled i/f?
Hi, is there any way to get SOPC to accept a custom component instead of the "on-chip RAM" as the tightly coupled instruction memory interface? I've tried everything I can think of but SOPC bui...
14 years agoDepending on the amount/type of debugging you need to do I think there is a JTAG -> avalon master block somewhere which might be enough for you.
I can imagine a system where you expose the nios soft reset bits, and have a piece of vhdl that copies code/data from a pre-initialised memory block into the nios code/data memory areas prior to removing the soft reset. You might then be able to use the jtag->avalon master block to update that 'pre-initialised' memory area and force a reset for development build and load.
