16 years agoSOPC + external Vhdl simulation
Hi, I'm programming 2 CycloneIII FPGAs (everything on PC, no HW), the 1st is simply a system of vhdl files interconnected each other, in the 2nd i've created a SOPC system as follows: ...
16 years agoOk that worked! the VHDL file communicate with SOPC, thanks!
but now when i run the nios program: #include <stdio.h>int main()
int n;
while (1)
printf("chose an option: \n 1 \n 2 \n 3 \n");
scanf("%d",&n);
printf("choice: %d \n", n);
return 0;
} i see in modelsim that some of the ports of the SOPC system (CORE.vhd) are like disconnected. component core is
port (
-- 1) global signals:
signal clk50mhz : in std_logic;
signal reset_n : in std_logic;
-- the_pio
signal in_port_to_the_pio : in std_logic_vector (15 downto 0);
signal out_port_from_the_pio : out std_logic_vector (15 downto 0);
-- the_uart
signal rxd_to_the_uart : in std_logic;
signal txd_from_the_uart : out std_logic
end component core; This port are without signal (exept for initialization) in_port_to_the_PIO, out_port_from_the_PIO, txd_from_the_UART. But using UART_log e UART_drive i can send and receive information!!! Why???
