15 years agoSoftware size is too big
Hello guys, i've tried small C lib, reduced device drivers and everything else but nothing works.. I am using Quartus V10.0SP1 and NIOSEDS V10.0SP1, A hello word simple program with a printf ta...
15 years ago --- Quote Start --- A hello word simple program with a printf takes 4k of onchip mem... that's impossible right? --- Quote End --- That could be quite normal: a complete printf implementation requires a lot of code. You must also account for the driver code which redirects the printf output string to the stdout device (i.e. jtag uart). Did you try the compiler directive -Os? This should optimise code size. Anyway, if your 4k code doesn't fit in a 10k memory, this is probably due to stack/heap or any data memory required by the stdio library and driver.
