11 years agosoc_system_board_info.xml/hps_common_board_info.xml common accross most devboards ?
I'm using De0-nano-soc & De1-soc from Terasic .. neither has soc_system_board_info.xml & hps_common_board_info.xml included in the packages that arrived & Terasic is claiming their linux s...
11 years agoupdate : booting . but not really
or i should say not completely on my own // i can create all it parts kernel/zImage/rootfs / boot.scr, soc_system.rbf, preloader-mkpimage.bin but it only boots if i use the socfpga.dtb from the sdcard that came with it (posted on the terasic site) .. . i have followed suggestions / remove second WDT, drop/disable peripherals in the soc_system.sopcinfo i have converted / modified/ loaded generated dts files i have unconverted the working blob to text& re'blob'ed it .. & it still boots / all others hang at "loading kernel ...." I've requested any board*info.xml from Terasic -- they do provide a version for the De1-SOC so it should not be a stretch for them to pass it on --- obviously the original device tree does me no good it does not support the peripherals i've created feeling some what stymied
